Rally Bulbs 160/100
I hate the lights in the car and years ago I had rally bulbs on an other car and they worked well but burned out the light switch. Think I had 160 / 100 but it was a while ago.
If I put a bulb like this on the car will it blow the switch? Or do I need to rewire and have the feed comming direct from the battery with a switch relay?
Its a better option than HID which don't seem to like the Octo lamps
You'd burn out the electrics and also melt the head lights using those bulbs, plus they are illegal to use on the road hence they say for off road use only
Regulations might be different in the ROI where CountryBoy is though (IIRC?)
I've come across Octavias with 100/80s. The lenses were glass, so there is no chance of melting.
The way this is done for rally purposes is to mount a relay immediately behind the headlight. The cable from the headlight switch controls the relay. The relay is fed via a fuse from the battery using thicker wire. Usually, the bulb socket and attached wire is also replaced to prevent it melting.
These are illegal and VOSA/Police do stop and check. A couple of months ago, I was stopped in a place called Cowbit (between Peterborough and Spalding). I had no problem as I had Philips Extremes in, but loads of drivers were getting done.
Just out of interest, do they check main beam as well? I've wondered if I might get a ahem, brighter bulb for main beam as it's a separate bulb on mine and main beam is only on when there's no one to dazzle.
Yes, they did. They checked the alignment too.
I had a chat to one of the coppers whilst they were checking my headlights. Using rally bulbs is more of a problem than HIDs out there. Narrow twisty roads, deep ditches and dazzling lights don't mix. Apparently, there have been a few cars go off the road after the drivers were 'blinded'.
Pre facelift octys were glass facelift ones are plastic think the shape of the pre facelift ones were different and won't fit?
Can't see what car he has due to using tapatalk
I don't think the glass ones will be any good either. even though the lens is glass, the rest of the light and the reflector is plastic, and if it melts/distorts, the beam pattern would be all over the shop.
Pre facelift lights are different too.
Well I've used these bulbs for years with no problems!!
Steve
Steve
Are they the 160/100. If so ill get a set today :rofl:
You just put them in with out any additional wiring?
I see halfords have a set of 130/90 which they claim are ok for plastic headlights (UV cut!!!)
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_164029_langId_-1_categoryId_165538_zygonArticleNum_176933_zygonGenericCode_000000_zygonId_10145111_zygonManPartNum_HBU472_zygonPrice_0
Edited by countryboyhaha
No alterations at all.
I certainly don't pay £10 a bulb though like those Halfords ones!!
I get mine from PartCo. on trade discount for a lot less!!
I also use 100w H3 fog light bulbs..... Guess what, they're ilegal too!! :rofl:
Steve
I use to use the higher power bulbs mate and had no issues emoticon-0143-smirk.gif now im a HID kit ****bag but hey ho i can see where im going emoticon-0136-giggle.gif
Makes me wonder how many laws are broken by just briskodians alone everyday emoticon-0104-surprised.gif
I had some 100/90W (H4) bulbs in my Suzuki for a while. They eventually fried the fuse box, causing the headlights to randomly turn on and off when they were on! Which was fun at night.
Ended up having to replace the fuse box. The lamps were glass, so never experienced any problems there.
I'm running 60/55W Philips X-treme Vision H4's (100% more light), and 55W Philips Blue Vision Ultra H3's in the Skoda. It's a pretty epic combo. Ideal for all the pitch black country lane hacking I do.
If you need more light than that, then you should probably get your eyes checked, or start eating more carrots!
One thing to note is that keeping your headlamps clean in the winter is critical. The Octavia lamps seem to be a dirt magnet!
Had the X-treme vision but they didnt last the year.
So guess ill put in the rally bulbs. Will do a but of extra wiring as a good feed from the battery can only help.
Had an Opel Nova (First car stop laughin) and they did fry the light switch so was a bit cautious putting them in the Skud.
And yeah the lights are a super dirt magnet .
Where did you get the kit and how bad is the skattering really, do you get flashed much.
Might just take the leap
I dont get flashed that often tbh
yeah they are bright but so are xenons as they come over hump and dips
i notch my beam down on the load thing, i think on 1 ........... maybe emoticon-0136-giggle.gif or i just leave it
http://www.hids-direct.co.uk/hid-kits-35w-canbuspro/h4-hilo-beam-hid-kits/h4-hilo-beam-twin-relay-canbus-pro-hid-conversion-kit-p-535.html
on the mot testers its not been to bad, one side is more precise than the other...... but i love them emoticon-0148-yes.gif
like i say "illegal is illegal" ............ be it speeding or lights emoticon-0105-wink.gif
It seems theres lots of things in life you not supose to do emoticon-0140-rofl.gif
Lloyd,
What rating are yours? 5000k?
Steve
Lloyd,
Steve
Mines the older kit, the none twin relay as ive had it a while and im very pleased emoticon-0148-yes.gif never had any issues with bulb out or dash lights either emoticon-0140-rofl.gif
I got some rally bulbs and fitted them this morning.
Will get HID in the new year once I get over xmas.
Cannt wait for the drive home to see the improvement.
If you do go for the hid kit mate the difference was eyes open - eyes shut :giggle:
Eyes shut if u look direct at them lol :rofl: sod it i'll say it 1st shall i ;)
Again tho, i do love them , very pleased :thumbup:
And that was going from £80 piaa h4 jimmys lol that were also very cool B)
But nothing on the hids lol
I will be going HID's its just I changed the wishbones, ball joints, rear beam bushing, Thermosat (tomorrow) and tracking done so far this month.
Will have to wait a while before I can get the HID's.
Rally bulbs will keep me going till then.
Thanks Steevie & Lloyd
Still have to fit the Boost gauge I have. Im so lazy
See what santa can bring you :smirk:
:giggle:
Ive got hids in mine best mod ive done so far. Never have any1 flash me yet and im running the 6k ones.
:giggle:
Is it too late to write to Santa :p
