Revs rising and dropping on there own
When the car has warmed up and idling the revs rise to just over 2k and drop back to 1k Every few seconds
Would that be an air leak somewhere?
Edited by Russ_vRS
could be or possibly a sign that the MAF is on the way out...
I had something similar on our Fabia and it turned out to be the coolant temperature sender - only a few quid to replace...
Its abit of a jerky ride too. On overrun the speed drops off quick too it's like the diverter valve has gone again.
On the drive home tonight I could hear the dv dumping boost when changing gear, I have the new revision one too
I had this on my mk5 gti and it turned out to be coils packs.
My vrs petrol mk2 had the same problem. Turned out the throttle control body was full of gunk. Stripped and cleaned and the problem went away. That was 2 plus years ago and all still fine.
The engine light come on today and I got 1 fault code and two pending fault codes which are
P0171
P0171 pending
P0441 pending
How can I check the maf, And clean the TB, will it need resetting and a gasket if I take it off to clean it?
Edited by Russ_vRS
