Checking Boost Pressure On VagCom
Is there an option to check the boost pressure in VagCom? I would of thought the ECU would need to know boost pressure as part of the fueling strategy?
Cheers, Andrew
Yes, can be monitored in measure blocks, then plotted to a graph if you wish to record it.
Somewhere around block 11 to 13 I think.
This. pretty sure at least on the vRS, group 11 is the section for requested and actual boost :thumbup:
sweet, cheers guys!
4th gear is best to use for logging.
Regarding the fueling. The smoke limiter map by standard goes of the MAF reading. However it can be changed to go of the MAP.
