Instrument Panel Light Dimming
1325324619[/url]' post='2627596']
I've heard about this...only two levels of diming.......and not in the user manual section on maxi-dot or anywhere else.....and not really adjustable "on the fly".....if you know what i mean!!
It's not on wheel as with the other skodas you have to tick it in the maxi- dot menu
  • Replies 60
  • Views 22.2k
  • Just picked up my shiny new greenline and driven back int he dark, dashboard lights did seem rather dazzling so would be interested in anyone who has found a switch for this too?
  • Probably I'm the only one who doesn't get bothered by the brightness of the lights :wonder:
  • IIRC, that is DSG clutch overheat warning light, but has no function for manuel transmissions.
My point exactly......."not adjustable on the fly"..........would prefer to have a "wheel" to adjust directly like I have on my MKI Fabia.......faffing around in the Maxi-dot for the single/double setting is not what I would call "user friendly"....which is why the above mod looks interesting!!!!!.. B)
1325333752[/url]' post='2627780']
I would be interested in the mod but not 100% sure if it would work, if you replaced that unit it would give you auto lights on when opening the door but would need to fit light sensor as well
Can someone answer this question.
Is the instrument light output adjustable or not ? If so, how ?
I've checked all the Maxi settings and there's nothing there. I've checked the owners manual and there's no mention whatsoever.
Apparently to do the auto lights you need a different switch to the one I quoted which does not have "auto lights"..which is why the switch I quoted is the "correct" one to just give you the additional dimming as the siemens dimming chip is built into the circuit board of the switch!!!!!!...... B)
Checking the "Daylight" box on my vRS does nothing to the instrument lighting. Headlights on or off.
What 'daylight' box ?
It's in the maxidot. Puts the clock forward an hour for summer time - saves having to faff about with hours and minutes and supposedly dims the instrument lighting when the headlights are turned on. (Doesn't work on mine.)
Maxidot/Setup/Time/Daylight.
1325537975[/url]' post='2630208']
Surely then the clock doesn't read the correct time then in order to use this function ?
1325542172[/url]' post='2630325']
Clock is fine? It does not work on time as this wouldn't work summer/ winter works when headlights come on, you have to have maxi- dot
1325339877[/url]' post='2627885']
Sorry just checked no I made a mistake! , it was on my superb 2 sooooo sorry emoticon-0103-cool.gif
So we are back to what i and the OP said.....no dimming of dash lighting unless you do the switch mod as described in the posts that are linked to and translated....... :wonder:
1325593213[/url]' post='2630700']
Aye I'm not bothering fed up with skoda, going to get rid and get a proper manufacturer, Volvo I think ?emoticon-0120-doh.gif
...... :giggle: ........know how you feel....I've got more "standard" kit on my MKI than you get on a MKII.....and they call that progress??????.... :wonder:
1325595673[/url]' post='2630756']
Try a Saab ?
Try a Saab ?
..... :giggle: ..........I'll give you a quid for the whole company....... :rofl: ......havn't you heard???
1325604722[/url]' post='2630897']
Try a Saab ?
emoticon-0140-rofl.gif Jaguar 2.0 crtdi, I wouldn't have to pay for sod all, cos I'm in the jag emoticon-0102-bigsmile.gif
That's Jaaaaaaag :D
The new range of Jags are lovely though and the XFR I'd seriously consider if I was older
I've been looking on the eBay for the Octavia switch and would this really work ? , pull the one out the fabia and stick an Octavia one in , surely it's more complicated than that?
Not looked, is there a place for a dimmer switch in the Fabia?
Like this one???
http://www.ebay.co.uk/itm/Skoda-Octavia-Light-Switch-3B0-941-531-/190617896653?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item2c61b646cd
From my post in the Roomster section...
My post re the info that I could get from the German sites!!!
Look at post 44
http://translate.google.co.uk/translate?hl=en&ie=UTF8&u=http://www.skodacommunity.de/skoda-forum/skoda-fabia-ii-forum/54566-armaturenbrett-beleuchtung-dimmen-beim-fabia-2-die-l%25C3%25B6sung/
http://www.passatplus.de/umbauteile/schalter/1U0941531A01C.jpg
3B0 941 531 A 01C * Light switch with fog light, green [Octavia] *
This is a rotary switch with the dimmer built into the switch (small knob on right side) from a MKI Octavia??
Translation quote...""""This light switch from the Skoda Octavia has the controls for the instrument lighting already integrated and can be exchanged for the normal light switch, if the old brightness slider was stalked. The lighting on the light switch pin is now an output, it would be a normal input. All this makes sense only if you have a car with xenon lights, where the Headlamp leveling system is missing already. Then the space freed up for other Tinkering can be used. For example, for a USB flash drive
All have the brightness control BTS730 Siemens chip inside, it can theoretically settle at room temperature of 100 degrees Celsius is still 10 amps. Chip also has an overload protection, over temperature protection and short circuit Protection, so really he should not go broke actually. """"""
And by reading the various threads it looks like you have to disconnect pin17 on plug (gr/bl Grey/blue???) wire and isolate, and then connect pin 16 (gr/gn Grey/Green????) to pin17!!!
Picture of plug and pin nos????
http://www.passatplus.de/umbauteile/stecker/1J0972999.jpg
Thats all the info I could translate, as it seems that a worker at the factory that makes them was giving advice!!!
B)
EDIT
Just had a look at the wiring info that I have for Fabia MKI (i know its different but uses similar switch as Octavia/Fabia MKII/Roomster) from Haynes
Headlight part of switch
Pin 1 = Black/red stripe = from ignition switch
Pin 4 = White/black stripe = to main/dip switch part of stalk
Pin 7 = Yellow/green stripe = to Fuses 54 (15A), 50 (15A), front dip beams, & Fuse 6 (5A) leveling motors
Foglight part of switch
Pin 2 = Red/black stripe = from "x" contact relief relay
Pin 8 = White/yellow stripe = Fuse 65 (15A) front fog lights
Pin 9 = Grey = Fuse 37 (7.5A) rear fog light
Sidelight part of switch
Pin 13 = Grey/black stripe = Fuse 34 (5A) to LH front side light and rear tail light
Pin 14 = Grey/red stripe = Fuse 333 (5A) to RH front side light and rear tail light
Pin 15 = Red = from Fuse 2 (110A) via terminal 30 junction
Pin 16 = Grey/blue stripe = Fuse 36 (5A) number plate lights
Misc
Pin 10 = Grey/blue stripe = from electrical system control unit for the switch illumination
Pin 10 = also labled as Brown = Earth = this could be a Haynes misprint!!!!
Pin 17 = Brown = Earth
Personally I would use a continuety tester and run it across all the pins on both the OEM and the Octi' switches to double check which pins/wires are for what then the switch is in all the different opperating positions!!!!
P.S. I take NO resposability for any mistakes/blow-ups/damage etc as a result of my information!!!!!....just covering my own back!!!. B)
  • 1 year later...
Hi!
Look at tachymeter. Between 8000 rpm and red zone coolant temperature. Is it light sensor for instrument cluster dimming?
Edited by Alexei
Hi!
I don't know what is this but I can tell you that my intsrument cluster has it too but I it's at the speedometer, by the way my cluster is not a maxidot but an mfd. I asked but never got answer, the best was an assumption that it is an empty position for some kind of warning light at more spec-ed cars. See the picture below it's in the red circle. I know it is not very clear but blame my old phone for that. Picture is 18 months old.
Edited by stratosg
