MAF showing fault
My MAF was recently replaced after showing up on the dignostics fault as
P0102
Mass or Volume Air Flow Circuit - Low input
or Mass or Volume Air Flow Circuit Low Input
AFTER a few a week the enginement mangement light has came back on now with a new code
P0101
Mass or Volume Air Flow Circuit Range/Performance Problem
DOES THIS MEAN MY maf HAS BROKEN AGAIN AND NEEDS REPLACED OR IS THIS SOMETHING DIFFERENT ?
P0102
P0101
Have you cleaned the small temperature sensor inside the MAF with some decent contact cleaner? (I suggested it a while ago in one of your threads as it work on our Toyota Yaris)
P0102
Do you still have the eBay maf sensor on? they are a really strange thing the mafs the cheap ones can play up, a friend got one from euro car parts which was spot on, might be worth a change.
Tom
Hi i havent cleaned it as i thought as it was brand new :(
also yes its one off ebay maybe i should just buy one from VAG :(
REALLY DOING MY HEAD IN NOW I SWITCH OFF THE LIGHT and a few days later the EML come back on for no reason grrr
OEM is the way forward, the eBay ones are sometimes unpredictable, in the case of MAFa it can mean buy cheap, buy twice.
