Something loose or rattling in tailgate?...and glovebox probs!
hi all. i have a vrs hatch 4 month old. since having it for a month or so there has been a rattling noise from inside of the tailgate near the washer or lock area. its clearly something loose and sounds like its made from metal as you can tell from the noise it makes. when i shut the boot lid it rattles and when driving it can sometimes be heard.
does anyone have any ideas what it could be or have had anything similar? ive kind of put up with it until now but im gona take it back to get looked at.
theres also an annoying squeeking/rattle noise from the l/h side glove box release arm. it goes when pressure is applied but obviously i cant push it in all the time when im driving!
any advice for the glove box issue as well??
thanks
Edited by ct110
I had a small rattle, took it back and the dealer fished one of those trim clips that hold the rear trim to the boot out. Fine afterwards.
rang up the dealers today and im going in this afternoon to get it checked out
ill give an update in case anyone else has a similar issue
Probably find the tailgate wants adjusting, they chatter if they aren't pulled down enough onto the rubber stops.
There is a small screw inside the rubber stops on the glovebox where the lids contacts, wind them out a little which puts the pressure on the lid and stops it squeaking/rattling.
took it to the dealers today and both things are sorted.
the rattle in the tailgate was a loose metal clip which they fixed back on and the guy took the glovebox out and put it back in and it seems to have sorted it as well.
if it starts again tho ill wind them screws out as suggested
Very common
I did the old electrical tape on my tailgate catch, to fix this
  • 3 months later...
I have the same problem, but I can't work out how to get the plastic cover off of the tailgate to investigate further? Help.
