ecu swop over
Hi guys with my stage 2 ecu coming any day know (cheers black vrs) i was wondering is there anything i should do when swaping them over i.e disconnect the battery etc. And am i right in thinking the ecu is underneath the scuttle panel and do i need any specialist tools. Cheers
question is do you have the same mods as the person selling the ecu??? as the map would have been done to suit his mods :thumbup:
Yeah all mods the same.
The scuttle panel comes off in two halves, the ECU is in a cradle underneath the middle. There are two multiplugs with plastic locking buttons on them that you remove then theres a metal clip you need to release to slide the ECU out of the cradle.
Should be do-able with a couple of flat bladed screwdrivers.
Not sure if there's any immobiliser coding in the ECU that will cause a problem or whether it works through the ignition. The only time I've removed the ECU we put it back into the same car.
Immo disabled on new ecu. Did u disconnect the batery when u undid the ecu.
Yep
