torque settings
can anyone give me the torqe wrench settings for the following please.
front wishbone bolts
driveshaft bolt (cv)
inner driveshaft bolts (six spline bolts)
brake caliper carrier
front anti roll bar bush brackets
tie bars (connected to shock absober and antiroll bar)
track rod end nuts
thanks
Lower arm mounting bolts 70nm and tighten a further 90 degrees.
Ball joint to lower arm bolts 20nm and tighten a further 90 degrees.
Ball joint nut 45nm.
Drive shaft to transmission
M8 40nm
M10 70nm
Brake carrier 120nm
Anti-roll bar clamp to subframe 25nm
Tie bar to roll bar 30nm
Track rod end lock nuts are usually just nipped up tight as you can only use a spanner not a wrench.
I hope these help :-)
