Windscreen wipers
Hi
First of all has any one else had problems with the intermittent / rain sensor setting on the windscreen wipers?
When clicked into position nothing happens if I then click the adjustment it will wipe once then nothing.
If any one has any ideas or wiring diagrams that would be top notch .
Turns out I need a new rain sensor which is behind the rear view mirror.
Thing is Skoda want £174.44 to fit and I cant find any place on the internet to purchase it my self emoticon-0106-crying.gifemoticon-0106-crying.gif
You can replace rain sensor, or you could just put a "normal" windscreen wiper relay (brown 377 or 389 one instead of grey 192 one). Then you do not need to touch rain sensor, and cost is far lower.
I replaced the auto relay on both Octavia and Superb. You get a lot more reliable intermittent wipe in place of dodgy automatic wipers, and wiper blades last much longer.
I use rainx and even at the lowest sensitivity the rain sensor would wipe the windscreen way too often. I even tried hacking the relay internals, but it made little difference.
Relay markings and colors
grey, with rain sensor, with/without headlight washer system (192)
brown, without rain sensor, with headlight washer system (389)
brown, without rain sensor, without headlight washer system (377)
Thanks both for your comments I think I will go with dieselv6's suggestion however as this seems the best idea,
