Fabia gearbox leak
Looking for someone to advise me on what I 'think' may be a missing gearbox bolt/grommet or whatever. Long story but while investigating a loss of power steering I've found an accumulation of oil under a hole in the gearbox.
It looks like something should go there but the hole is not threaded so it can't be a bolt. Any ideas?
Here's a summary of what I've found:
  • Picture shows underside of gearbox. Image in upper right is just an enlarged view of that area
  • Looking up through the hole I can see a toothed cog so to me I reckon this should be sealed. Perhaps I'm wrong?
  • Have looked up on ELSAWIN and can't get a clear view on what should be there
  • Car has total loss of power steering. Power steering error light on and was the original reason for investigation
  • Included RossTech VCDS log. Don't believe it's relevant to the gearbox issue but may provide context for someone more knowledgable than myself
  • YouTube video showing area can be viewed here (around 20 seconds into the video you'll see a comment)
Fighting fires on a few fronts here so don't want this thread to venture into steering etc, will keep it focused on what appears to be a gearbox leak.
Car details – Skoda Fabia VRS TDI, 2006, right hand drive UK car.
New to the forum, apologies if I've missed some useful info and thanks in advance for any help.
VCDS log (for info only, don't see any gearbox specific related issues here)
Friday,23,December,2011,23:59:42:10074
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 6Y - Skoda Fabia I
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56 76
VIN: TMBWU26Y27******* Mileage: 171770km/106732miles
Address 01: Engine Labels: 038-906-019-ASZ.lbl
Part No: 038 906 019 NJ
Component: 1,9l R4 EDC G000SG 7331
Coding: 00102
Shop #: WSC 13765
VCID: 6CD3C083361B
TMBWU26Y27******* SKZ7Z0F3620207
4 Faults Found:
17068 - Glow Plug Control Module (J179): Implausible Signal
P0684 - 35-10 - - - Intermittent
19463 - Camshaft Position Sensor (G40): No Signal
P3007 - 35-10 - - - Intermittent
18058 - Powertrain Data Bus: Missing Message from Instrument Cluster
P1650 - 35-10 - - - Intermittent
17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
P1144 - 35-00 - -
Readiness: 1 2 0 0 0
Address 03: ABS Brakes Labels: 6R0-907-37x-ESP.lbl
Part No SW: 6Q0 907 379 AQ HW: 6Q0 907 379 AQ
Component: ESP 8.0 front H04 0002
Revision: 00000000 Serial number: 00000000000000
Coding: 0000296
Shop #: WSC 13765 000 00000
VCID: 8C13200396DB
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 61
Mileage: 171769 km
Time Indication: 0
Address 08: Auto HVAC Labels: 6Q0-820-045.lbl
Part No: 6Y0 820 045
Component: Klimaanlage X0840
VCID: F2EF5EFB943F
1 Fault Found:
01596 - Motor for Outside/Recirculated Air Flap (V154)
30-10 - Open or Short to Plus - Intermittent
Address 09: Cent. Elect. Labels: 6Qx-937-049-C.lbl
Part No: 6Q1 937 049 D
Component: 0000 BN-SG. 1S34
Coding: 26030
Shop #: WSC 13765
VCID: 3C7330C306FB
4 Faults Found:
01309 - Power Steering Control Module (J500)
49-00 - No Communications
49-10 - No Communications - Intermittent
00975 - Heated Rear Window (Z1)
28-10 - Short to Plus - Intermittent
01598 - Drive Battery Voltage
07-10 - Signal too Low - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 1C0 909 605 K
Component: 01 AIRBAG VW51 08 0009
Coding: 12337
Shop #: WSC 13765
VCID: 2C530083F69B
2 Faults Found:
00532 - Supply Voltage B+
Address 17: Instruments Labels: 6Y0-920-xx3-17.lbl
Part No: 6Y0 920 973 S
Component: KOMBIINSTRUMENT VDO V04
Coding: 28402
Shop #: WSC 13765
VCID: 50AB7473BA73
1 Fault Found:
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: 003M GATEWAY CAN 1S34
Coding: 00014
Shop #: WSC 13765
VCID: F0EB54F39A33
2 Faults Found:
Address 25: Immobilizer Labels: 5J0-920-xxx-25.clb
Component: IMMOBILIZER VDO V04
Coding: 28402
Shop #: WSC 13765
VCID: 50AB7473BA73
No fault code found.
Address 46: Central Conv. Labels: 6Q0-959-433.lbl
Part No: 6Q0 959 433 E
Component: 60 Komfortger·t 0002
Coding: 00018
Shop #: WSC 13765
VCID: 3D753DC71DE1
1 Fault Found:
00849 - S-contact at Ignition/Starter Switch (D)
25-10 - Unknown Switch Condition - Intermittent
Address 55: Xenon Range Labels: None
Part No: 6N0 907 503
Component: Leuchtweiteregelung 0005
Coding: 00010
Shop #: WSC 13765
VCID: ECD34083B61B
Address 56: Radio Labels: 1U0-035-156.lbl
Part No: 6Y0 035 156 E
Component: Radio YD5 0015
Coding: 00403
Shop #: WSC 13765
VCID: 387B2CD332C3
4 Faults Found:
00878 - Connection to Speaker Front Left
36-10 - Open Circuit - Intermittent
00879 - Connection to Speaker Front Right
00880 - Connection to Speaker Rear Left
00881 - Connection to Speaker Rear Right
End ---------------------------------------------------------------------
the other side of that hole is inside the bell housing if you have oil coming out of it then you could have a rear crank oil seal leak or a input shaft seal leak
Thanks Nath, much appreciated. Should the hole be covered with something? In other words, should I be looking to replace a lost part?
I'm thinking yes and a trip to the Skoda dealer suggests so but the chap didn't seem too sure. Hoping the Skoda ETKA files will confirm but don't have them installed yet.
No it shouldn't be covered as if it does let oil to leak from the clutch bell housing then it needs to be open to allow the oil to drain to try and prevent contamination of the friction lining. If you can tell, the condition of the oil will tell you where it is coming from. Relatively clean will mean it is coming from gearbox input seal, dirty black oil will mean it is coming from the crankshaft rear main seal.
Ian
