Front Door Removal
hey all, just wondering if there are any guides (or how-tos) on removing a fabia front door. i have had a quick search but can find anything. any help would be great
rich
Pretty sure you unclip the wiring from the a pillar, just one connector once you unclip the rubber boot from the top.
Then there should be a M8 bolt holding the check strap on, then one 13mm bolt under a plastic cap per door hinge and the door lifts off.
Rich, are you starting a new trend then eh?:giggle:
cheers tech1e :p will have a look
Estate Man: my logic is; the fewer the doors, the fewer the windows, hence less de-icing time.....
