abs fault
hi all
i have a octavia mk 2 06 with a abs fault on it 00668 supply voltage terminal 30 and 00285 abs wheel speed sensor front right g45 electrical fault in circuit so i have changed the sensor and got the wiring loom from skoda can any one tell me were to find the ends of the wiring loom in car please thanks andy
You need to sort out the terminal 30 problem before anything else. If one of the modules are losing power then any other faults may be spurious.
Which module is reporting the the terminal 30 fault and is it the only one?
Which loom did you buy?
ok were do i find modules and can i swap them about to see if fault moves its saying front right cheers and wiring loom is from abs sensor to inside the car throughout inner wing but can not see were it goes in the car just joined it to the old one cheers
