225 / 45 / 17 tyre pressure
ok i have 225/45/17 tyres on my vrs what tyre pressure do you guys use with this set up? i normally run whatever is said in the fuel flap but these are not the standard tyre!
i ran 32 all round on the bora with the same tyre size.
found it gave best even wear
I'm running what the fuel cap says, which is the same as my previous Octy with the same tyres
32psi Front and 33psi Rear ;)
When I was running them on the front of my octy I put them at 2.3 bar in an attempt to get some of my lost mpg back, which didn't work. But tyre wear was even on both of them.
It would of been cheaper for me to have brought 205's in the first place as I lost atleast 5mpg! There was hardly any difference between the 2 in grip or road holding, slightly harsher ride and reduced mpg. Going back to 205's when its time to put the summer tyres on
thanks all
i run 32/33 on fronts with 225/45. 29 is too low with this tyre
