Audi TT wishbone bushes
hello, will audi tt wishbone bushes fit the octavia front arm? im led to believe that they are solid type rubber? please correct me if im wrong.
cheers
mike
You are correct
Audi TT rear bush that looks like a donut (solid in construction, does not have voids like the vrs one).
Part No: - 8N0 407 181B
ARB clamp bolts = 25Nm
Wishbone pivot/mounting bolts (front and rear) = 70Nm + 90 degrees
Ball joint to wishbone bolts = 20Nm + 90 degrees
Ball joint nut = 45Nm
Don't buy the cheap ones off ebay they last about 10 miles before falling to bits, get the pattern part 25quid ones in blue box's if you do get them off ebay
