electric fault abs
00668 supply voltage terminal 30 can any one help
Hi andy id check the fuse for the ABS if thats ok id check the wiring and plug going to the module if thats ok id change the module...good luck :-)
hi thanks were can i find the module to check wires and plug ? cheers
The module/ABS Pump/Modulator is in the engine bay a small silver block with brake lines and a plug coming off it. If you change it you will have to get the new one coded.
cheers i have a new wiring loom for drivers side with cable ends on it do u know were they are in the car to change wires go through wing into car but can not find them cheers
You would probably have to unscrew the wheel arch lining but if it is plugged in at both ends I doubt the wiring will be damaged its more likley to be a fault with the module.
hi no plug on one end 2 wires on other must wire up to some were in car drivers side but i can not find them cheers
Sorry mate never had to change the wiring. Try tracing the wire from the wheel speed sensor and module.
