Clutch slipping! Help please!
Even with a uprated clutch and flywheel I dont find myself sitting at 1500-1700rpm then booting it tbh. I tend to drive it much more petrol like
It's down to personal driving style. I class 2krpm as the start of the powerband to which I want to use.
2000rpm isnt going to cause any issues though, especially with a map as you dont get the big lump of torque at 1900rpm that I remember the standard mapping having, unless you constantly doing it in 6th gear which is a bit pointless. Anything below that in higher gears will be the time when its causing issues/damage.
Thanks for addressing my concerns. So as long as I'm over 1500ish revs it should be safe before occasionally booting it?
2k+ rpm, but its mainly in higher gears that it causes issues. Sat at 30mph in 5th them flooring it is the kind situation you want to avoid. You`ll find when its mapped the power is moved up the rev range anyway, so unless cruising, you`ll be better of with a few move rev`s to make good progress. :thumbup: This is based on my experience and advice from clever techie people. :rofl:
someone put this company on the forum the other day
http://www.clutch-specialists.co.uk/
i got this email from them the other day
We build a 6 paddle cerametalic clutch kit for your car, These kits are one
of our best sellers
the two piece clutch is £280.00
the hydraulic slave cylinder is £45.00
and the Dual mass flywheel is £275.00
I can sell these as a full replacement kit for £575.00
with free postage
Kindest Regards
Linda
Edited by bluepassion
Thanks for all the info people. I will be getting a standard setup then I will get my map looked at.
Who did the map in the first place?
I don't know who mapped the car. It was mapped when I picked it up from Rainworth Skoda Mansfield. I'm not happy with the service they gave me at all.
Tell them you want the standard map back on and a new clutch :)
I can't see them doing that, I've had a few issues with them in the past. Very unhelpful
