Cheap discs and pads? cupra r brembo's?
Hi, should probs be in the Leon mk1 section over on SCN but I'm not a member.
Where can I get some cheap standard/patent 323 discs and pads for my LCR set-up?
second hand will do too. Don't plan on keeping them long and the money I spend on this is money not saved for 8pot's...
Ross
Ross
Try euro car parts
http://www.google.co.uk/aclk?sa=l&ai=CXSn5-SQHT_2SCYKJOt6tjf8P2qjlsQKi0r-rJK6SwwsIABABIOasrgsoA1Cmh792YLuWvYPQCqABmJHo6gPIAQGpAjrU_xIp77k-qgQhT9D6KjopSDoFSmuehmLdma-Z-gH1_3m1qHBBhfezUGW_gAWQTg&sig=AOD64_1GaY32MajyQmA-im0wShNYXcU_CQ&ved=0CBEQ0Qw&adurl=http://www.eurocarparts.com/Car-Parts
If you have the OE part numbers you require, feel free to drop us a PM here
1ML 615 301 Discs
1ML 698 151 Pads
1ML 615 301 Discs
1ML 698 151 Pads
Desc: Pagid Brake Disc
OE Ref: 1ML 615 301
Part No.: 104790018
Web Price: £99.60 (Priced Per Disc)
Forum Price: £74.70 each
Properties
Ø 323 mm, Height 34,2 mm, Brake Disc Type Internally Vented, Br. Disc Thickness 28 mm, Min. thickness 26 mm, Num. of holes 5, Centering Diameter 65 mm, Art.No. S2000V
http://www.eurocarparts.com/search/104790018/p/home
Desc: Pagid Brake Pads
OE Ref: 1ML 698 151
Part No.: 101790068
Web Price: £34.20
Forum Price: £25.65
Properties
Width 109,7 mm, Height 69,3 mm, Thickness/Strength 15 mm, With integrated wear sensor, WVA Number 24143, Brake System Brembo
http://www.eurocarparts.com/search/101790068/p/home
