New air scoop!
The ITG is bigger than the forge and much bigger than the apollo. That's for a reason.
There's two ways of reducing the filter restriction.
1- larger surface area
2- make the filter less restrictive allowing larger particles through.
I see that Apollo as coming under number 2. Id be happier in the knowledge that my filter was actually filtering the incoming air to the correct standard.
You can order the parts for an ITG and build your own. Much cheaper option.
Where can you get the housing part, I've seen the filters but didn't know u could get the rest.
Spoke to the lad today and he said he wouldn't mind making a few up:
He has some 75mm OD intercooler pipe that he can use as the cool air feed, he should have enough of that to make one.
If you want a specific size he can get it but will take a bit longer to make. He has another one made up but he has done it out of one piece and has been bent to the correct shape, he's going to bring it in tomorrow so i can see it, i'll take a few pic's and post them up.
He's asked for £35 inc postage un-painted, or £45 powder coated.
Thats not too bad a price to be honest!
Is he going to make you the ally pipe for the cold air feed or are you just gonna use the normal cold feed tube stuff?
I'll probably just buy a some more intercooler pipe a joiner and extend it to where I need
  • 4 weeks later...
If anybody is interested the lad has made another one up:
If anyone would like me to fit it to mine to give them an idea of where it comes to etc.
It has a 76mm / 3" outlet on it. £40 delivered
Hmm
i might even build my own intake.....£40 is a bit steep though
If the ITG gives the gains it does with the air feed behind the headlight I'd leave it well alone as well jonny
Si if you are interested in it send me a pm with an offer an ill ring him and ask him
Not just yet. Other plans first, but ill degintely be up forit at a later date. Expensive month got custom remap to pay for tomorrow and holiday at disney land
I could be intrested depending if i sell my old wheels and check that my idea will fit in the space
Just let me know if you are after one, he can make the outlet to what size you like.
Just PM me if you sell the wheels, good luck ;)
