daytime running lights turned off
whether anyone knows how can I turn off the automatic lights burning day, fabia II elegance equipment, the manual says that there is a switch with a fuse with which it can be done but the car does it
If anyone has any idea
Do you have the switch by the diagnostic connection?
If you take off the plastic cover fir the fuses to the right of the steering wheel, there is a rocker switch to turn them on or off
I believe that in croatia you'll find the fuse box under the steering wheel. Gently pull the cover off and you will find the switch right next too the diagnostics connection.
This will nake the drls light up when no dipped beam are used. When you turn on dipped beam DRL will not work but you get cornering lights instead.
does not switch, at the direction where it should be there it is just a hole
1325961104[/url]' post='2636242']
No switch on continental cars as its compulsory to have DRLs?, UK not compulsory yet emoticon-0103-cool.gif
All new cars in the UK need DRLs from November 2011.
duplicate
1326102922[/url]' post='2638327']
? Not compulsory to have them switched on from that date yet, however the OP is in Croatia and is law in all euro area emoticon-0104-surprised.gif
Thought the law in Croatia was headlights on all the time?
Was when I visited a few years ago.
1326210075[/url]' post='2640140']
Not sure about headlights drls are though, if fitted emoticon-0140-rofl.gif Otherwise put fogs on like the rest of the idiotsemoticon-0104-surprised.gif
I'm pretty sure someone said that all new cars after a certain date must have drl's fitted by law...
