Vrs electric windows not working
Hi guys, I got up this morning and went for a spin, tried to open the front windows both are not working at all. Away to check the fuse now. Anybody else had this problem?
Yes - might be a dirty/loose fuse
Checked fuse. All ok then started working again....fine. Got up this morning windows not working again
hi im having the exact same problem happens to be during heavy rainfall then when they seem to dry out they work must be a leak or something
Check the wiring in the door shut.
What would i be looking for i took the door card of yesterday and dint see much wrong
Did you look at the wiring in the rubber boot in the door shut though?
yea the door shut seems to be leaking in water the gromet seems to have peeled away from the door
The door shut will always have water in it, there isnt a seal around it?
Normally they stop working as the wiring breaks in the rubber boot where it flexes but if your boot isnt secure then i'd expect its corroded out terminals in the plug(s)onto the car.
ok man thanks il have a look at that today
Cheers will check it out
Just thought i would let you know,i have had the same problem,cleaned then chenged the fuses no luck,booked it in then yesterday gave the switch a push and wow all working again no reason just working,so maybe if you can sit on it for awhile and it might fix it self?.
Did you ever get this sorted as my electric windows have stopped working too - have checked the fuses but all is ok with them?
No still haven't got this working so annoying
I am going to book mine in the local Skoda garage as I need a new passenger electric window button too, I'll let you know what the outcome is!
i have had the same problems for ages now anyone any idea where i can find the controller unit for the electric windows
Guys, I just opened the door and waggled the rubber with the wires inside has worked fine ever since.
I have taken my door card apart and checked all the wires fuses ect still wont work only works in the rain. Would i be safer buying a new motor and trying that or checking the convenience control unit
