Water leaking
Just bought a second hand Fabia VRS - water leaks in around the rear nearside door. Footwell soaking wet! Anyothers had this problem?
ynnek
Does your rear wash work?
Try the Mk1 fabia section for a solution as I suspect its the known issue related to the door carrier/seals
Definitely rain water. Done check on rear washer hose! Good shout though and thank you! :)
Time to seal the INFAMOUS rear door carriers with gloop.
