help required
Hi i have a couple of faults with my 99 octy estate can anyone help ?
* instrument cluster failiure - i have removed fuse 15 to enable me to have a speedo again after resoildering the vaultage regulator on the pcb board inside the cluster this worked for about a week the failed again
* ABS light on but goes off intermitantly - i have had the car on diagnostics it was the drivers front sensor so i changed the sensor and the fault still occurs
many thanks steve
cluster failure fix does not only require the soldering on the voltage regulator, have a look at link
abs error -> have you considered a wiring fault ?
many thanks for the link :) i shall have the cluster out this weekend ...
as for the abs i cant find any breaks or damage to the sensor wire ill have to investigate further
many thanks steve
no prob ;)
good luck finding the cause of the fault
