Greenline Se : Few Questions
1. Will it have daytime running lights?
2. Will there be space for a spare wheel in the normal location?
3. I've just got the standard 4 spoke steering wheel - were will the cruise control controls be located (stalk/wheel)?
4. Will it have motion active central locking?
5. Will I be able to open the boot without leaving the car?
Thanks all
Mine is not a Greenline but is 2009 SE...
1. Will it have daytime running lights? Yes - should be switchable through Multi Functional Display (I assume this applies to the DRL's that are now in the fogs)
2. Will there be space for a spare wheel in the normal location? Yes there should be
3. I've just got the standard 4 spoke steering wheel - were will the cruise control controls be located (stalk/wheel)?Left hand stalk
4. Will it have motion active central locking? Yes - again can be set through the MFD
5. Will I be able to open the boot without leaving the car?Yes, but only by taking the key from the ignition and pressing the button!
Thanks all
Edited by JustinCombi
Thanks Justin
I have a SuperB Greenline Estate:
All the things Justin mentioned are true but please pay attention that the spare wheel has to be purchased afterwards and you'd also need to purchase its mounting rack. If you're gonna purchase them from a Skoda dealer, that's gonna be quite expensive.
There are two things which are quite annoying with the Greenline: no possibility to have a spare wheel and no possibility to have a parking heater :doh:
Edit: and yeah, although it's "Greenline", the use of biodiesel is prohibited ;)
Edited by Sensonic
