brakes
hi got a skoda octavia tdi when brakeing and nearly stopping my abs comes on not the light
Havent you already posted?
thats a statement, so whats the question?
he's wondering why it's doing it i guess. have a mate with a passat doing the same, he says it's from a damaged abs sensor
perhaps he could write and give us a bit more info
ABS sensor or the ABS ring in the hub. Vagcom diagnostic should point to the problem.
I had the same problem on a Mondeo ST TDCI, & it was caused by a broken ABS ring.
or the abs is working under hard braking, which it should, in which case the light wont flash up
