What is standard boost?
What is the standard boost pressure on a vrs?
I think it's 1.3 bar.
WOW! you people with your diesels and silly high boost.
Thanks :D
Correct :)
Thanks :D
2.3 bar for me :D
2.3 bar standard (absolute)
Just in case your reading vag com and getting confused..lol
Ahhh this was what I was wondering.
So 2.3bar is read from the map? but the turbo is actually running at 1.3?
IE. If I T a mechanical boost guage into the vac lines the guage would read 1.3? (ish)
Edited by Disiesel
yes. VCDS will read 1 bar of pressure at tickover. :) (or 980mbar to 1030mbar depending on the weather :D)
There is no boost vacuum line to tap in to (like a petrol) - you have to physically tap into the boost pipework somehow. There are options.
Thanks for that.
Is there not a vac line on..uh..dammit. Its near the back of the engine bay next to the throttle body. Kinda looks like a dump valve. I will have a search anyway.
There are vacuum lines, but boost does not run through any of them. They control other things like turbo actuation
Thanks for that.
I suspect your looking at the EGR valve.
2340 in the map :)
Mines peaks at 3 bar/ 30 psi and levels off to around 2.5 bar.
Hybrid turbo, does seem quite high?
What power is that running?!
No print as yet, due to not having a remap. But running same engine mods as Luke leary and his is around 240bhp.
I dont think his is running that kinda boost though!? I`m running a similar set up, same turbo, cooler, mapper and was running 200bhp on 1.7bar! Cant see it needing that much more pressure for an extra 20-40bhp. :wonder:
We including atmosphere pressure?
