Felicia driver side door lock
Now here's a funny thing. The driver side door ill unlock the central locking, but won't lock the doors. I've had the panel off and had a look, All is attached as it ought to be.
With the door open and the latch in the door closed position, I can operate the the central locking by the top "button" but not from the key.
Oh clever people, what do you think the problem is? Door lock itself? :wonder:
Edited by Gwiz
Firstly compare it with the passengers side, the lock barrels have a slotted plastic part fitted if this is broken or the outside barrel of the lock casting is broken then it wont work.
On mine both fronts are like this so I can only lock all doors from one of the rear doors.
Good luck at the scrappy Gwiz.
