Fuse box location?
wheres the fuse box located in a fabia vrs?! can i hell find it! :'(
drivers side on the side of the dash
I thought it was the passenger side?
does that mean i have to take bits of the dash off?
anyone got a pick as i still cant find it!
Easy open the drivers door.....the dark grey end panel (in the centre of the end...which covers 90% of the end) on the part of the dash that faces the door is the fuse box cover......there is a slot near the bottom edge...insert the ignition key into this slot and lever up the panel so it totally comes off!....... B)
Pic of the manual.
Open drivers door, The vertical end panel, There's a little notch in the bottom use your key to lever it off!
As above, deffo drivers side.
<p>sorry to hi jack....found the fuse box, what fuse would be for the boot interior lighting....checked the bulb and its ok. cheers!</p>
Pic of the manual.
That's the manual for a LHD car, the fusebox changes sides along with the dash (presumably as that's where the majority of wiring is needed so it makes the wiring looms simpler and probably more reliable (since the less wiring you have, the less there is to go wrong, rub through shielding, get knackered by radio installations, etc, etc?). The wording in that pic should read "the drivers side" rather than "the left side" to make it accurate for UK cars
Right hand side end of the dash. Just pulls off and clips back in easily enough :)
Simples . Head for Halfrauds. BUY MANUAL , NO 4376 , and see where the fuse is.
