Skoda Felicia - lambda/o2 sensors?
Looking at buying a new lambda sensor as I'm getting horrific milage (<20mpg).
Are they the same on the 1.6 engines. I saw on ebay that they are listed as the same four wire sensors (same part number), and even on most, if not all the Skoda/VW engines (part number 032 906 265 E).
Edited by Violet
Hi
The part number you quote is for a vw polo 2000-2002 only, not listed for any other models. the correct part number for a 1.6 felica is 6U0 906 265C
Tony
The 1.3 and 1.6 models have the same lambda probe but the cable is slightly different length hence the different part numbers but they can easily interchange between models.... However they are specific to the felicia as the polo ones have a different type of wiring plug fitted but the actual probe is the same and you could hack the plug off and swap it over if you were desperate.
Would this be an option to improve my economy - I've changed the CTS so far - not sure what else?
