Help with engine code
After many reliable miles, my MPI is displaying the engine code P0304, the engine runs rough and misses on 4 but only until the engine gets up to temperature and then runs fine. Ive been told that it shouldn't be the coil or plugs because that would be a constant problem. Could it be a leaking injector, running rich? would be grateful for any help or advice.
That's a generic code reader fault output, but does point towards an issue with a misfire on cylinder 4.
A bit more info and possible reasons:
http://www.obd-codes.com/p0304
