2.0 TDI CR Problem
Are you all aware?
http://www-odi.nhtsa.dot.gov/cars/problems/defect/defectsummary2.cfm?inv_id=22524&type=VEHICLE&typenum=1&cmpt_id=158&prod_id=954770&make=VOLKSWAGEN&model=JETTA%20SPORTWAGEN&model_yr=2011
NHTSA Campaign ID Number: PE11023
Vehicle Make / Model: Model Year(s):
AUDI / A3 2009-2012
VOLKSWAGEN / GOLF 2009-2012
VOLKSWAGEN / JETTA 2009-2012
VOLKSWAGEN / JETTA SPORTWAGEN 2009-2012
Manufacturer: VOLKSWAGEN OF AMERICA, INC
Component(s):
FUEL SYSTEM, DIESEL
Summary:
By letter dated October 3, 2011, Volkswagen Group of America, Inc. (VW) notified the National Highway Traffic Safety Administration (NHTSA) that it will conduct a safety recall to address a defect in approximately 168,275 model year (MY) 2009-2012 Volkswagen Jetta, Jetta Sportwagen, Golf, and Audi A3 vehicles equipped with the 2.0L TDI Common Rail Clean Diesel engine (NHTSA Recall No. 11V-490). The recalled Jetta and Jetta Sportwagen vehicles were built from May 2008 through September 2011, the Golf vehicles were built from May 2009 through September 2011, and the Audi A3 vehicles were built from September 2009 through September 2011. According to Volkswagen, in U.S. applications of the above cited TDI vehicles including engine codes CJAA and CBEA, the fuel injection pulses could coincide with the natural frequency of the injector line #2 in specific load and RPM conditions. This resonance creates additional stress on the fuel line which a small number of parts (based on the statistic spread of line strength) cannot withstand over its lifetime. As a contributing factor, VW indicated that a supplier used tube material with scratch marks from a grinding process during certain production periods. Lines manufactured in these periods were installed in vehicles produced in the following 10 months: December 2008, January-February 2009, October 2009, March-April 2010 and September-December 2010. Injector lines using this material exhibit a significantly higher failure rate. Dealers will replace injector line #2 in all vehicles built in these months. In addition, as a precautionary measure, all recalled vehicles will have vibration dampers installed on all four fuel injector lines. Analysis of NHTSA complaints, VW complaints, VW field reports and warranty claims found allegations of injector line leakage in 443 subject vehicles. The leaking line was not identified in 62 of the vehicles. For the 381 that did provide information about which injector lines were leaking and/or replaced, 358 (94%) involved an injector line #2 leak/repair. Almost three-quarters of the injector line #2 leak/repair incident vehicles were built in the 10 months identified by VW, which accounted for approximately one-quarter of the recalled vehicles. The failure rate for injector line #2 in vehicles built in the 10 months affected by the supplier line scratching issue is 6.0 incidents per thousand vehicles (IPTV). The failure rate for injector line #2 in other production months of recalled vehicles is 0.8 IPTV. The leak/repair rates for the other injector lines are all well under 1 IPTV. The action taken by Volkswagen is sufficient to resolve the issues raised by this investigation. The agency will continue to monitor this issue and reserves the right to take further action if warranted by the circumstances. Accordingly, this investigation is closed.
Date Investigation Opened: August 2, 2011
Date Investigation Closed: December 2, 2011
Yeah there are a couple of threads running on it already.
