Have any of you enabled via VCDS on a 2011 VRS....?
Tried to enable some features for a member today and all the options in coding were blank. Adaption gave errors about ECU not being seen/unknown/ready etc
They wanted the unlock as key removed and large MPH reading on maxidot (didnt know this was possible on maxidot).
The only thing I could do out of what he wanted was change the country to AUS but that ddnt seem to have the desired effect of the large MPH display, so after a lot of agro with VCDS saying I couldnt apply changes back, set back as GB.
Has anyone enabled these on a 2011 VRS?
Mine is the same... :thumbdown:
not done the functions you describe (the maxidot on the fabia is much limited compaired to the octy!) but I did get rid of the stupid security lock that only unlocks the drivers door when you press the button, it now unlocks everything :)
this was jason who did this for me... someone else (I forget who) tried to access at a york meet, and couldnt get anything at all to respond, so wouldn't have been able to change anything!
I dont know much about it, but i would assume a different software version between the two?
I managed to get my Feb 2011 car updated with Anti Hijack locking, Auto unlock on key removel and alarm beep all done with VCDS. I'll contact the member in question to see if he can shed any light.
oh yeah, jason also put anti-hijack on for me :thumbup: I didnt bother with the alarm beep ;)
Once you have changed the country with VCDS you then need to untick the Alt. Speed Disp. box in the maxidot.
So close but not quite!!
I have done several walk through's on here showing how to do this,.some with screen shots.
I got that far, but didn't give the large speedo they wanted, just removed the kph?
Could you possible ask this member to contact me so i could arrange a meet with them! or can this only be done if you have maxidot? :) ?
Edited by zach1301
That'll be me then!
What's you locus?
That'll be me then!
What's you locus?
Miles away! in Yorkshire!! Not going to be passing by anytime soon are you? ha
