2000 felicia low beam lights NOT working
My wife's 2000 skoda felicia low beams NOT working. Brought new bulbs and everything was the same. High beams work OK. what other areas should I be looking at?
hi, if both of them are not working it's more than likely the stalk switch has failed, The switch on the dash must be working otherwise you wouldn't be able to switch on the main beam, the stalk on the steering column just alternates between low and high beam.
