VRS Clutch options?
Hi,
Today I noticed my clutch started to slip when I boosted a bit in 4th.
I knew the clutch would let go eventually, as its on 85k and been mapped to 380lb torque.
Uprated clutches are at bit expensive at the moment as moving out in a few months, but I will have to get one if I have to.
Would a brand new standard clutch last for around 20/30k? Or just eat it again?
Can anyone link me a few they recommend for my power?
And answers about standard clutch.
Thanks in advance.
Liam.
380lbft of torque? Are you sure? If it's really that much then buying a new standard one is pretty pointless, they're only rated to hold 300lbft, so as soon as you started using the power again it would be a case of counting down until it started slipping. For me, I'd be using a Sachs Race organic clutch, and if it really is 380lbft then you'll probably want/need to upgrade to a single mass flywheel, the dual mass on mine started to fail when I had a torque spike up to that level, and even though the torque was then pulled back the damage was done.
Cant imagine your running 380ft but if you are I would get a different map before any clutch.
I've heard standard equipment LUK clutch kits are good
Mapped by shark, says that on my dyno printout.
Sent from my iPhone 5 using Tapatalk.
Shark run in Nm, that's why I was asking. 380Nm is around 280ftlb :) I sent you a PM, let me know if it's of any interest to you.
