Fabia VRS Better Air Filter
where do i get of of these, i had one for my old saxo, but i cant find one for the furby so any suggestions?
Green Panel filter, search for that and you will have more than enough information
hth :)
All the Fabia range share the same air box except the 1.4-16v IIRC, so the one you buy might be marked 1.4-8v, but it will fit fine. Part number can be found here
Chris
You might wat to add a Cupra Intake pipe to the airbox as well to get more air into it in the first place :thumbup:
On a loose engine in standard set up with the Green filter and Cupra intake it's good for about 10bhp*
*figures qouted from JabbaSport
Hi Jason,
HEre's some juicy stuff for you......I drive a Fab 1.48v. I started out using GREEN panel filter, P 950337, but have since taken out my airbox and installed the GREEN Twister induction kit. Here are some pics of te initial installation, I've since changed to a much shorter intake for both into the Twister and into the Throttle body.....enjoy... :thumbup:
3820.attach
3821.attach
3822.attach
