P0401 fault code
Hi - For 2005 Octavia 1.9Tdi (later shape model) can any one advise on what to replace for fault code P0401. Main dealer said they can drill down with their testing capability and identify the part that needs replacing. With testing and part it would be in the region of £170. Does anyone konow if that fault code is specific to a single part or several?
If the part is fitted does the fault code turn off or does it have to be reset so the engine management light goes off?
Thanks for your help.
I am almost certain that is the code for an EGR fault......
Could mean it's blocked, or damaged. If you are mechanically minded you could remove it and check - although iirc the 1.9 is at the back of the engine against the bulkhead. I have a EGR delete pipe fitted to my 2.0 PD140 and it activated a CEL, I had it mapped out when I remapped the car, but the dealer or possibly someone with VCDS locally could turn off the light.
By the way what mileage has your car done?
Hi, thanks for your reply mine has done 75,000 miles and is on variable servicing. I did disconnent the hose from the throtle valve and have a look at the EGR valve as best i could. From what i could see it was not heavily laden with oily residue. Thanks Rob
Try this site for a complete explanation: Ross-Tech Wiki
An EGR valve is about a ton and I would suggest (IMHO) 170 fitted is about right. However, if the EGR is blocked the inlet manifold might be too. http://www.myturbodiesel.com/1000q/a5/clean-intake-manifold-PD.htm
Might be worth asking what they propose to do about that?
edit: fix URL
Edited by FriendlyFire
Hi thanks for your advice and for providing the links. Regards
Rob
From ross-tech wiki
16785/P0401/001025 - Exhaust Gas Recirculation (EGR) System: Insufficient Flow Detected
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Reduced Exhaust Gas Recirculation (EGR)
Reduced Power Output/Engine running rough
Increased Emissions
Possible Causes
Exhaust Gas Recirculation (EGR) Flow restricted/clogged
Exhaust Gas Recirculation (EGR) Valve stuck closed/leaking/faulty
Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve faulty
Exhaust Gas Recirculation (EGR) System faulty
Possible Solutions
Check/Clean Exhaust Gas Recirculation (EGR) System
Check/Replace Exhaust Gas Recirculation (EGR) Valve
Check Wiring and/or Connector(s) from/to Exhaust Gas Recirculation (EGR) Valve
From ross-tech wiki
Possible Symptoms
Increased Emissions
Possible Causes
Possible Solutions
