Vango Sherpa 65 Rucsac
Hello all,
I'm unsure if people will be interested in this but it's worth a shot!
I have 1 x Vango Sherpa 65 Rucsac from my sister travelling. This is in good condition but does have 1 slight tear in the top of the bag which could be fixed if you are indeed good with a needle and thread.
Blurb:
A Vango classic as the name suggests it will take you higher and further than you could go alone and you'll get there in good shape. New fabrics and new styling have updated this core product in the Vango range. Great value, available with classic pocket or expansion pockets, depending on how much you want this Sherpa to carry. Ideal for DofE expeditions and longer stays away from home. Duke of Edinburgh's Award Recommended Kit.
Features
•SA Self Adjust carry system - A simplified version of the Pumori Bi-Radial® chassis A3 system with the same adjustment. It is robust, highly tested and will fit almost all back lengths.
•Excel® 300D ripstop polyester contrast - A tough fabric with sewn in threads creating a strong Ripstop and abrasion resistant fabric.
•Excel® 600D shadow polyester body - A strong, durable fabric with shadow ripstop weave providing excellent tear-proof strength and a distinct visual.
•Excel® 1680D polyester base - Robust PU texturised polyester applies - strength, durability and abrasion resistance - perfect where super strength is required at the base of our larger rucsacs.
•Short (S) and Regular back lengths available. 'S' in style name denotes Short model. - Designed to accommodate females or males who require a shorter torso fit. The harness is also designed to fi t a smaller frame for optimum comfort
•Shaped adjustable harness - For optimum fit and comfort
•Shaped ergonomic hip belt - Shaped for comfort and load carrying
•Airmesh on body contact points - Keeps the user dry and cool
•Sternum strap with emergency whistle - Adjustable secure fit and easy to reach safety feature - note this whistle is positioned in a downwards direction to prevent water entering the whistle and freezing
•Top lid access with twin buckle closure - Easy access to pack contents
•Zippered base compartment - Allows flexibility, ease of packing and the ability to separate items from the main compartment
•Expandable side zip pockets - Extra capacity when required. (Classic fixed volume zippered side pockets on 65L)
•Twin wand pockets - Easy access to items such as water bottle or snacks
•Zip map pocket - Zipped compartment perfect size and positioning for a map
•Top lid with zippered pocket - Easy access and safe storage of small items
•Hydration compatible - Convenient liquid supply on the move
•Detachable Rain Cover included - Keeps gear safe and dry; bright orange for visibility
•Ice axe/walking pole attachment point - Easy to carry and access essential safety gear
•Dual side compression straps (not on 65L) - Secures and compresses load for comfort and stability
•Shock cord accessory web - Quick and easy stowaway
•Grab handles at top and side - Well positioned, shaped handle - additional carry options
•Optional zipped compartment divider - For full use of the compartment the compartment divider can be opened, to separate items within the rucsac the zip divides the compartment into two sections
•Internal key clip - Attachment to keep keys secure
•Shoulder fit tab - A guide to the fit of the rucsac
•Easy to find lining - Lining colour aids finding dark objects in the bottom of the rucsac
•DuraFlex buckles - Fasteners renowned for strength, quality and durability
•Vango 'U' shaped zip pulls - Easy to find and operate shaped zip pulls
Specifications:
Volume : 65 litres
Weight : 2.64kg
Pictures:
**£40.00**
If you do have any questions, please do contact me.
Many thanks,
Rob.
