Electric seat memory problem
Hi all,
Just bought my 2006 '56' Octavia TDI Laurin + Klement and the electric seat moves on its own, I put it to normal position again and still moves of its own accord.
Any ideas what it could be?
I appreciate your advice please!
Thanks in advance!
Edited by lionyo
Hi all,
Thanks in advance!
My boss has just had his BMW back for something very similar, turned out to be a loose wire under the seat.
I was thinking it could be some sort of seat switch or control module?
the seat is probably programmed to your key fob and just need resetting to your own personal settings
Assigning remote control to the memory buttons
After storing the settings of the seat and exterior mirrors, you
have 10 seconds in order to assign the remote control to the
appropriate memory button.
– Withdraw the ignition key.
– Press the button for unlocking the vehicle. The
setting is stored with the memory button which you have
selected.
  • 2 years later...
selected.
Is this the right way to store the setting.?
and if not done, the seat will keep moving with its own.?
