rear suspension adjustment
how easy/costly is it to adjust the rear suspension to help stop sawtoothing of the tyres
IIRC it cost me £70 for the full 4 wheel alignment.
Yes, but that is with multilink suspension where OP had rear beam.
Ozzyboy... there is no adjustment in general but what you have to check if your beam aint bent. Then only shims or swap wil help. First you need to know what is wrong and for that someone need to check alignment and get you print out.
