central locking re locks when un locked
can any body help, i have trawled through some feeds - but they seem not tp be quite the same. my central locking was fine apart from the drivers side door has been tempermental & now wont un lock or open.but today, when i unlock using the fob, the car relocks before you can open the door.i have tried both fobs. if i use the key & hold it across the drivers door opens along with the windows. any ideas? as i not diy minded.one feed said try the washers pipe under the cd unit for water etc? i will try to take the door card out tomorrow. can anybody recommed someone to have alook [ i am in wymondham norfolk ]
Sounds like one of the locks is jammed possibly the drivers one so its bouncing back causing the rest to lock again
There's a connector block in the drivers door that is prone to getting rain water in it, which corrodes the contact pins. Worth checking that 1st.
