Brake lights stuck on
I have an Octavia 2 and the brake lights are stuck on. I have replaced the brake light switch and it hasn't helped. A VW specialist has fitted another new switch which hasn't helped. A new Central electrics/ onboard supply control unit has been tried with no success. When the engine control unit fuse is removed the brake lights go out. The only fault showing up relates to the brake light switch. Has anyone any suggestions? Does a gateway control unit seem likely?
