Hand Brake...
This is my first ever brand new car and was just wondering if i need to get the hand brake tightened up? I know when you get a new hand brake fitted they advise you to take it back in a week or 2 to get it tightened as they stretch... is this the case with new cars? and if so where should it be taken? the dealers?
thanks
It should self-adjust, so you don't need to worry about it. If it doesn't, take it to the dealer.
thanks !
Also you can do it from here ;)
Edited by irfant
Normally something you would do AFTER having work done, say to replace cables etc...
The service schedule should do a routine inspection and adjust if needed. Enjoy!
That's my take too . Last year ,my MK1 needed the rear shoes loosening off.Had a look at haynes for shoe adjustment - "press the brake pedal and they'll self adjust " . If the MK2 self adjust is the same - it's that simple that it has to be seen to be appreciated - it's a wedge , driven by gravity ,and a spring . Otherwise ,you've got the lads(and ladies) at the dealers to sort out any problems for the next couple of years .Mine was two and a half years old when I got it. Only had two problems , one of which was sorted in minutes by local dealer .The other was door cards .
Only ever had to adjust a handbrake cable .But that old lady was sitting on over 150k ,and it was British.
Edited by VWD
