interior light fuse
please can you tell me where the fuse is for the interior lights.all have gone off including boot.also is there a upgrade boot bulb which i can put in as standard one is not bright enough.thanks
There is a whole thread on the boot lights just do a search is your best bet but i just swapped the bulb out for a W5W LED 8 SMD bulb off of ebay kicks out the same amount of light as the superskoda mod
but on the fuse front the fuse box is located on the right hand vertical side of the dashboard you have to open the drivers door to access it and you need your key or something flat to prise off the cover to access the fuses i believe the internal lights fuse is on the left hand side of the panel and is the 9th fuse up from the bottom on the left hand side.
Edited by Yetigreenline2
just to confirm it was the 9th fuse up(10amp red) from the bottom on the left hand side.it was located on the right hand side of the dash board and not under next to the footwell.thanks for advice looking into a new bulb now.
