how to fit boost gauge?
Hi guys ive been reading forums and pages an pages of information but cant find the pipe im suppose to fit the gauge to. If possible a picture of the engine bay with pipe highlighted would be fantastic.
Thanks for help
Is it a gauge the shows vacuum aswell??
Thanks mate knew i had read this but couldnt find it again even doin a search thanks a million
No worries :thumbup:
I've got the Forge recirc kit and it uses a vacuum take of block which is ideal as i get vacuum and boost at this point you can also use a self sealing screw in nipple on the L shape pipe at the top and back of engine. Will get a pic if you want it
Was reading about the forge fitting kit but was unsure of where the block actually fitted(as most instructions found where for the 2.0l). i like the idea of using the kit but can i justify the £35/£40 for the kit when i can get everythin (boost gauge, t piece and pipe) for say £40 quid?? is there an advantage to getting the vacuum?? After going though pages i also found out there are a few suppliers of gauge fitting kits like forge for simliar pricing.
Oh and a picture would be brilliant
Edited by leevrs180
Forge do a kit for the 2.0l but not the 1.4 as far as I'm aware. The kit i have replaces the stock dv and happens to use a block that sits between the intake manifold and manifold sensor. It is over 150 quid and not really needed unless you taking the car quite far tuning wise. I'll get a pic of the L shape pipe which can be used. Do you already have the gauge??
No i dont. waiting for pay day and having a look about at gauges atm trying to find one that does the purpose i need and doesnt brake the bank
If you get one showing only boost and not vacuum it will be a far easier install and probably cheaper to buy aswell.
