Light help
I want to change the front,rear indicator to led if possible do these need to be canbus ones also the brake light.
You have to use resistors due to the indicators would blink too fast with LEDs. Or you could change the flashing relay, but apparently it is integrated in the dash on fabia II.. Tech1e might know if it's possible to exchange that..
You can use error free LEDs with no issue but the brake light ones are pants tho just stick to oem
Why not just change them to silvertecs bud? Or did you want a higher output of light?
Do you have leds fitted as indicators and with no errors/superflashing?
I ordered normal indicators but silver glass and led tail lights as they were canbus ones hope they ok
I fitted led lights to the brake lights but keep getting error builb on dash these are canbus lights is there away round this.
