electrical problem --need help ;;please
hi! i gest bought skoda octavia 1.6 year 2003 and i have a problem . when i turn on the dipped lights in the intrerior everythinks it is ok the dashboard light it is ok but the lights from the ventilation system ( fan, heat and air position) dosen,t work ,,,, and the lighter it is working but the light aroud lighter and boot dosen,t work ,,,,,,do you have any ideea what i can do ? it may be a fuse ? or the lights burned ? thanks a lot !! appologize for the bad engilsh ...
If you have the three dials for the air then the middle one has a bulb in it (you need to take the front of the dial off to replace it)
For the lighter I think there is a small bulb in the plastic around the handbrake that the lighter fits in, you would have to take that plastic off to find the bulb
THANk YOU CHICKEN_EYEBROW !!!!!! you was right i replaced today and it is working now :-) !!!
