Changing front sidelight bulbs.
Hi.
Does anyone know how to remove the wiring connector that sits at the bottom of headlight.
I have undone the plastic nut, pulled the lever and removed the headlight so far foreward. I then need to disconnect the wiring connecter, I have tried pulling it off to no avail. Is there a clip somewere?
Do I need to remove this to change a sidelight bulb?
Hey
theres not enough wire to pull the headlight out the connector needs to be taken off there a clip on the underside of the connector give it a squeeze below and pull back. Its tight but it does come a wee wiggle might be needed.
it is a real PIA but makes getting to the sidelight so much easier if you can get them off. Same as most of the other electrical connectors used around the engine - have a look at another one that is more accessible to see how they undo.
Even when the light is out getting to the sidelight bulb is a pain to remove - seem to remember that strong needle nose pliers are a great help!
Thaks for the info have now managed to disconnect
