fitting hands free kit
hi just wondering if anyone has fitted a parrot hands free kit and where they have put it on the dash as I'm not sure where to put mine??
I have.
It's to the left of the steering wheel on the little silver trim.
Switched live is on the back of fuse 19.
Tis a half hour job.
thanks for that does anyone have any pics i could look at its the mki3100 getting it fitted tommorrow
I had a ck3100 on my last 58 plate octavia and a bury on my 12 plate and they both tolerated the control panel going top middle above the stereo and just below the hazard switch with the cable passing under the stereo surround trim.
The control unit sits behind the ashtray area to the side.
Power and earth off the stereo and ignition live is off the heater control loom or rear of the head lamp switch on all models.
Run the microphone out from the glasses pocket overhead(plastic clips lock out on the sides with glasses flap open) and not the interior light assembly as that has sharp edges.
Would suggest you use a populated sot lead rather than direct input on the rear of the stereo as you can Get bad echo for the person on the other end of your call on these stereos or a single seperate speaker doesn't have that problem at all.
Good luck.
Andy.
Edited by andyrno1
or if you haven't already bought the Parrot, why not fit a genuine VAG kit instead? It's not hard to fit, there are loads on ebay, On a later vehicle it will integrate nicely with the Maxidot and head unit. I just don't get why you would use an aftermarket unit when the genuine article is so good?
i have the maxidot with the sat nav nexus model i think it is!! could you point out what i would need as i would prefer factory look tbh
