Code Error Reader no need for Vag Com
Cant VAGCOM do all that even without activation?
i was looking at this item and i feel very tempted to get one considering its only
VAG-COM is free to download and has a better interface - from the looks of that description, it can only display codes, rather than text descriptions on the problem?
Chris
More info here
Phil
VAG-COM is free to download and has a better interface - from the looks of that description' date=' it can only display codes, rather than text descriptions on the problem?
Chris[/quote']
might be free, but isn't the cable on the expensive side of things?
Depends where you buy it from ;) Laptop may set you back a few quid though :rofl:
Chris
More info here
That makes more sense - so I guess it's down to how comprehensive the manual is :D
Chris
Chris
thats exactly it
The OBD 2 scan tool claims to display over 700 possible error codes. VAG-COM has a database of more than 7500 error codes and decodes these.
I found the info below on Ross-Tech's site:
What's the difference between VAG-COM and an OBD-II Scan-Tool?
OBD-II is a government mandated diagnostic protocol that is primarily aimed at diagnosing emissions-related problems. An OBD-II scan tool will work in many different brands of cars. VAG-COM uses VW's proprietary diagnostic protocol and will only work in VW/Audi vehicles. Although you can use an OBD-II Scan Tool in an OBD-II compliant (1996 or newer) VW or Audi, an OBD-II Scan Tool can only talk to the engine, not the numerous other "intelligent" systems in the car. Want to reprogram your central locks or your Radio? Diagnose a problem with your ABS, Airbags, or Automatic Transmission? Re-align your Immobilizer after swapping ECU's? Reset your Service Reminder Indicators? Communicate with a pre-1996 model (not OBD-II compliant) car? An OBD-II Scan-Tool can't do any of these things. Please see our OBD-II Page for information on using third party generic OBD-II software through our Interface. Want some reasons to choose VAG-COM over a generic OBD-II scan tool? See this Real World Comparison.
OBD-II is a government mandated diagnostic protocol that is primarily aimed at diagnosing emissions-related problems. An OBD-II scan tool will work in many different brands of cars. VAG-COM uses VW's proprietary diagnostic protocol and will only work in VW/Audi vehicles. Although you can use an OBD-II Scan Tool in an OBD-II compliant (1996 or newer) VW or Audi' date=' an OBD-II Scan Tool can only talk to the engine, not the numerous other "intelligent" systems in the car. Want to reprogram your central locks or your Radio? Diagnose a problem with your ABS, Airbags, or Automatic Transmission? Re-align your Immobilizer after swapping ECU's? Reset your Service Reminder Indicators? Communicate with a pre-1996 model (not OBD-II compliant) car? An OBD-II Scan-Tool can't do any of these things. Please see our OBD-II Page for information on using third party generic OBD-II software through our Interface. Want some reasons to choose VAG-COM over a generic OBD-II scan tool? See this Real World Comparison.[/quote']
thanks for that DGW...
Allow it then i say and get Vag Com..
Joel
