Torque limits for DSG?
Anyone know what the safe max torque to put through the DSG of Octavia RS FL 2.0 TDI CR 170 hp year 2011.?
I took this from the best man in the the Irish Republic to remap etc.
http://www.chippedire.com/
TDR performance has assembled a DSG upgrade suited to the FSI and TDI units . The DSG is a brilliant piece of technology, and TDR has now perfected how it operates ,giving full control .This is a project I've been working on for a long time , tuning and testing Dsg gearboxes both in Europe and USA
Features:
• Torque limit increased from 350NM to 500NM
TDR DSG software has increased the DSG Gearbox’s ability to transmit torque while still ensuring the stability and capability of all the hardware within the DSG gearbox. If you are running performance engine software, this flash is a must to ensure the DSG gearbox can make full use of the engines power. The stock DSG software is able to override your engine ECU once it sees power in excess of its factory programmed 350NM torque limit.
• Fast, Progressive Shift response
Through careful calibration , we are able to progressively increase the responsiveness of the gear shift , reducing reaction times from 0.4 sec to 0.08 seconds, shift time is approximately 30% faster than factory. From half load to full throttle, it is nearly 70% faster to respond. This means less lag when working the paddles; and more consistent and predictable shifting when you need it.
• Auto shift in Manual Mode Disabled
We give you back true control when running in Manual mode. No more up-shift or down-shift at inopportune times while in M mode
Dsg Tuning is available for all the 6 speed DSG units 2005-2012
