Help with fault codes
Hi all, i am new to VCDS, but I scanned my octavia and it came up with this fault codes. I did a scan because the light check engine is on and I wanted to know, with your help I hope, what is the problem.
I checked it on RossTech Wiki this fault codes but still don't understand what it means. that car drives and feels ok in city but when I am on motorway and I have 70 mph she enter in limp mode.
Any helpful info would be much appreciated.
Skoda Octavia 2.0 TDI 2005 DSG
Friday,24,February,2012,15:03:23:10074
VCDS Version: Release 10.6.4
Data version: 20110418
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
Mileage: 135460km/84170miles
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 DS HW: 028 101 195 3
Component: R4 2,0L EDC G000AG 7000
Revision: 12345678 Serial number: SKZ7Z0E3076640
Coding: 0000078
Shop #: WSC 73430 790 00000
VCID: 77F9EFEF7F5D
3 Faults Found:
· 16785 - EGR System: Insufficient Flow
P0401 - 000 - -
Freeze Frame:
RPM: 1722 /min
Torque: 84.0 Nm
Speed: 53.0 km/h
Load: 26.3 %
Duty Cycle: 14.7 %
Bin. Bits: 00101000
Mass Air / Rev.: 255.0 mg/str
Mass Air / Rev.: 490.0 mg/str
· 16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
P0234 - 000 - -
Freeze Frame:
RPM: 2583 /min
Torque: 144.0 Nm
Speed: 131.0 km/h
Load: 48.6 %
Voltage: 14.36 V
Bin. Bits: 00101000
Absolute Pres.: 1550.4 mbar
Absolute Pres.: 1866.6 mbar
Readiness: 1 1 0 0 0
17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault
P0672 - 000 - -
Freeze Frame:
RPM: 777 /min
Torque: 64.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101011
Temperature: 16.2°C
Bin. Bits: 10110000
PS. I also made a log-view attach files
LOG-01-003-010-011.xls
Edited by iulian.uk
Chassis Type: 1K0
Coding: 0000078
VCID: 77F9EFEF7F5D
3 Faults Found:
P0401 - 000 - -
Freeze Frame:
RPM: 1722 /min
Torque: 84.0 Nm
Speed: 53.0 km/h
Load: 26.3 %
Duty Cycle: 14.7 %
Bin. Bits: 00101000
P0234 - 000 - -
Freeze Frame:
RPM: 2583 /min
Torque: 144.0 Nm
Speed: 131.0 km/h
Load: 48.6 %
Voltage: 14.36 V
Bin. Bits: 00101000
P0672 - 000 - -
Freeze Frame:
RPM: 777 /min
Torque: 64.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 14.21 V
Bin. Bits: 00101011
Temperature: 16.2°C
Bin. Bits: 10110000
Hello mate since you are getting rough running at a reasonable load (48%) and at a reasonable speed (80mph) ;-) it seems it is getting force fed too much air probably due to the diverter valve stuck closed/sticking or the wastegate not opening both of these components help to relieve or increase turbo boost pressure. You mite also want to check hoses are connected OK and not split. As for the glow plug fault it may or may not be related the incorrect air to fuel ratio would cause bad starting tho which may bring up a glow plug fault. The EGR wouldnt cause misfire or limp mode under load so maybe that fault is seperate or flaggng up because the whole engine management system is linked. At worst a faulty EGR would cause rough idle. Id fix the turbo fault causing rough running first then re-scan. Good luck :-)
Edited by 07 vRS Taxi
